Budgeted Units Import&Export
18 years 8 months
I only change budgeted unit data using p6 excel spreadsheet template; however it is not changed.
19 years 2 months
Did you export the current budgeted units to Excel via the export to xls function?  If so as long as you only change the data and not the structure of the file (headings, tab names) then this should work.  Your other option is to do the same but using the SDK.
