Resource Usage Report
19 years
David,
Unfortunately max Unit/Time will not average or show in the summary band. It is like a text that will not summarize. If you need to show them use the detail report and run pivot table on excel. That would help.
21 years 6 months
Rodel.... it appears to be something to do with the ’show summaries only’ tick box within group and sort?
When ticked the max units/time data is not on the report, when not ticked the data is there. Only problem is that I only require the summary list... do you know anyway around this?
Thanks in advance
21 years 6 months
Hi Rodel, I have chosen the same? Under columns all I have is Activity name and Max Units/Time. Group and Sort I have Resource ID name. Filter I have where open state equals open AND Resource type equals nonlabor (whichis what I need. Time interval period I have budgeted units?
I’ll keeping trying meantime, many thanks
19 years
David,
What subject did you select when setting up the report? I just run a Activity resource & roles assignment with Max unit/time column added and it has all the data.
