Global Change Fields
Hi all,
Any help with this would be very much appreciated, I’m writing a very basic global change, for some reason when I come add the value in the ‘Parameter/Value’ field within the ‘Then’ section the only options I have are from a drop-down listing (that happen to be my codes),, I would like to add an integer in this field i.e. 2,, what am I doing wrong?
Many thanks
Jon
Jon,
You are saying the Budget Qty is a UDF?
See this image:
Hi Raymund,
thnaks again for your help,, I would like to have a global change that makes the Original Duration = Budget Quantity / 2
my problem is entering the 2 into the 'Parameter/Value' field,
hope this makes sense?
many thanks
What specific field are you trying to input a custom value?
very much appreciate all of the kind help on this, however i dont have the 'customs' option,, would this be anything to do with my user privilages?
Just to continue Raymund post, Choose Customs from the drop down menu of the Parameter/Value field.
If you click on the box, a drop down menu will appear, and scrolling up, you will find "Customs".
Hi Raymund,
Thank you for your reply,, apologies if i am missing something obvious,, where is the drop down to choose the 'customs' field?
Many thanks
Jon,
Choose Customs from the drop down menu.
