P6 Stand Alone Slow performance
9 replies [Last post]
Sampath Lakshmi N...
User offline. Last seen 6 years 44 weeks ago. Offline
Dear all
Kindly help me in this matter. I have p6 standalone.I am working in multiple projects. Few days it was working good. One fine day every project just opening it self taking 2 hrs time. Then even importing and opening of projects are taking too long time (More than 1 Hr). Kindly suggest me a way to work out.....
Thanks in Advance
User offline. Last seen 14 weeks 3 hours ago. Offline
do this
Go to start
All programs
Select Microsoft SQL Server 2005
Then Microsoft SQL Server Management Studio
Server name is the name of your computer\PRIMAVERA
Authentication is SQL Server Authentication
Login: sa
Password is: Prima123Vera
Select Connect
On the left expand the databases and select pmdb$primavera
Uptop select New Query
on the right type this
update statistics project with fullscan ,all
update statistics task with fullscan, all
Then right click execute
Then type
exec sp_updatestats
Khuong Do
User offline. Last seen 18 weeks 6 days ago. Offline
You can try below solution:
When using Primavera P6 with Microsoft SQL Server database, we can have problem like this:- Loading Data hangs at 98%.- Performance issues in SQL Server.- Opening projects is slow.- PM.exe not responding after entering username and password.- Project Management window disappears after loading data.- Cannot login to PM, no error. Here is the solution to solve above problem: https://doduykhuong.com/2018/05/10/primavera-p6-sql-server-database-slow-loading-data-performance-issue/
Dieter Wambach
User offline. Last seen 8 years 23 weeks ago. Offline
Luca
Maybe you’ll first try backup and restore. "Corrupt" might be too many extensions of some tables which may lead to "out of memory".
Luca Basile
User offline. Last seen 10 years 34 weeks ago. Offline
Groups: TILOS
what I found out that if I import several schedules into the DB after a while it get corrupted and need to re-install a brand new DB
Generally with the DB corrupted my system performance was very bad
L
Arnold Puy
You are welcome..
Thank you once again Mr.Arnold.
Thanks alot for ur technical sugestion. I will try in that way and reply you. Any way so kind of u..
warm regards
Lakshmi Narayanan
Arnold Puy
Hi Sampath,
Based on my experience to my windows xp laptop, shrinking decrease the usage capacity of my database and the performance is quite better than before. I am not sure if you should re-arrange first before shrink. But it works fine without doing that. But, make sure to backup your database.
Try to reduce the data from your database and just import again the moment you will need it. This is also what I am doing.
Arnold
Thank you very much Mr.Arnold. I have checked your first option which is correct. I am using windows xp. Can you tell me whether shrinking of data base will give effect in performance of primavera and should i use re arrage before shrinking...?
Thank you once agin for ur help
warm regards
Lakshmi Narayanan
Arnold Puy
Hi Sampath,
1. Try to check your Edit --> User Preferences --> Startup Filters, all mark must be under the "Current date project only".
2. If you are using windows vista try to change the setting from your Control Panel --> Power Option --> Preferred Plans, then select "High performance".
3. You can compress or Shrink your database using the "SQL Server Management Studio Express".
Hope this helps.
Arnold
