Progress Curve
6 replies [Last post]
Emmanuel Udo
User offline. Last seen 6 years 27 weeks ago. Offline
I need to modify the vertical axes of the progress curve.
The curve was developed using expense values. But I need to remove the $ signs and possible replace it with %. Is this possible? has somebody done it before?
Please, advise.
Emmanuel
sachin sangai
User offline. Last seen 10 years 5 weeks ago. Offline
hi guys
Thanks for the help. but can I keep different scales for the histogram and the curve and can i show the values (Data labels) as we can in excel.
sach
Henk van der Heide
User offline. Last seen 7 years 27 weeks ago. Offline
Dinesh,
Yes you’re right i misunderstood
You have to divide by your total budget and multiply by hundred (or as you say divide by total budget/100) works very fine.
regards
Henk
Dinesh Kumar Dama...
User offline. Last seen 9 years 23 weeks ago. Offline
Hi Henk,
I tried it and it works.Let’s say you have a planned value of 37000000, you devide it by 370000 and include % sign in the unit of measure.The planned value will be shown as 100% and actuals and earned value will be calculated and shown accordingly.Try it.
Thanks & regards
Dinesh
Henk van der Heide
Hi Dinesh,
I dont think this is the same.
The meaning is to see the % of the total budget (total budget is 100%). to do this you have to divide through the total budget. Not a number like 10/100 or 1000.
Henk
May be you can try to use the following :
Under activity profile/resource profile, choose profile options >graph tab > tick calculate average >devide the total shown on the profile by 10 if it is in 1000 and 100 if it is in 10000 and so on >type % in the units of measure> apply.
Thanks & regards
Dinesh
Henk van der Heide
It’s not possible to set % on one of the Axis.
You better make a timedistributed report, dump it to excel.
The new release will have this option (so i’m told).
Henk
