Copying a cost loaded project
9 replies [Last post]
Cristina Boston
User offline. Last seen 14 years 6 weeks ago. Offline
I created a copy of a (cost loaded) project in P6. I wonder why in Projects the Total Activities & BAC columns for the copy show 0 (zero).
When I open the copy, it’s fine; has all the data & info I need. But...guess what...the original project gets...depleted from this info (showing 0 activites & costs).
Can anybody explain me what is happeening or why?
Dieter Wambach
User offline. Last seen 8 years 9 weeks ago. Offline
Gern geschehen! (You’re welcome)
Cristina Boston
Danke schon Dieter!:~)
Cristina
Dieter Wambach
Cristina
This is the right approach - we created an EPS-branch "Archive" with special access rights. Change the project status to "What-if".
In addition check the entry under Edit --> User Preferences --> Resource Analysis. It’s self explaining and should be according to your needs.
Cristina Boston
OK, I think I found a way. I created a new branch in the EPS structure for Project Copies, and will locate all my copies in there.
Cristina
Cristina Boston
Now the problem is...hmmm...the system adds up the data(activites & budget) from my original project + copies. Now I understand why the copies were showing a zero before summarizing.
Where should I locate the copies in order not to affect the EPS info?
Thankfully,
Cristina (obviously I am a beginner in P6)
Cristina Boston
It worked. Thank you guys. Now the data shows on all projects (original + copies).
Cristina
Dieter Wambach
Cristina
Tools --> Summarize --> Open Projects (or All Projects if not open)
James Shimmon
User offline. Last seen 14 years 37 weeks ago. Offline
Cristina
The only thing I can think of is to open and summarise the copied project then the info should show up in the projects view
Shimmo
Arnold Puy
User offline. Last seen 10 years 20 weeks ago. Offline
Hi Cristina,
Sorry, it’s not so clear can you explain a little bit in detail.
Arnold
