What is a project life cycle?
11 replies [Last post]
Marcio Sampaio
User offline. Last seen 11 years 34 weeks ago. Offline
Dear all;
How can i define "project life cycle" using simple words??
Regards.
Marcio Sampaio
Thank u all for the participation!!
Many differents opinions ... all very good.
That is what i expect from this forum.
Thanks again.
Marcio Eduardo.
Norzul Ibrahim
User offline. Last seen 16 years 27 weeks ago. Offline
conceptual >> feasibility study >> basic engineering design >> detailed engineering design >> procurement >> construction >> commissioning >> performance testing >> provisional acceptance >> handover >> warranty period >> final acceptance >> operation >> rejuvenation/revamp >> the cycle continues....
Marcio Sampaio
David,
Thanks for your response.
My definition of a project cycle is from "Cradle to Grave"
There is always a logical sequence of work packages which can represent this, for example,
Identify requirement
Conceptual Study
Design
Manufacture
Commission, Test & Deliver
Through life costs
Product Retirement
These elements are common to almost any type of project.
Marcio Sampaio
Thanks again Julie!!
Very good grafic and very good site ... i didn’t know this.
Best regards.
Marcio Eduardo
Rio de Janeiro - Brazil.
Julie Scully
User offline. Last seen 16 years 26 weeks ago. Offline
PCS have a graphical representation of a typical project lifecycle which you may find beneficial.
www.pcs-pl.com.au/pm_services.shtml
Marcio Sampaio
see this other response ...
If a project is well organized, it will progress logically through several phases. There are four
standard phases to a typical project. The first two "concept" and "development" involve planning,
that is to say, identifying the concept and then developing this concept and the plan to accomplish it
as we have discussed. This usually leads to a formal submission of the plan (project brief) at which
a go or no-go decision is given on the basis of the plan. If approved, this leads to the second two
phases which are the accomplishment phases of implementing and finishing. As the names imply,
this means converting ideas on paper to reality and getting the job finished and turned over to the
customer.
Of course, different people in different project environments use different names but the principles
are the same. Also, projects in different fields may require the four standard phases to be broken
down further into stages such as separate feasibility studies; detailed design and working drawings;
procurement; construction; training, commissioning and transfer.
Regards.
Marcio Sampaio
Jaco and Naveen;
Thanks a lot!!
Regards.
Marcio.
Jaco Stadler
User offline. Last seen 17 years 28 weeks ago. Offline
Project Life Cycle
Start of with an Idea
Then and OME study
Then a DFS Study
Then Implementation
Implementation is Broken Down to Engineering - Procurement - Fabrication - Construction - Commissioning - Project Close Out
Some time More than one DFS is done on different "What If" Idea’s and normally the cheapest win. Please note Interem Phases etc are also sometimes used.
Cheer
Naveen Nayak
User offline. Last seen 7 years 39 weeks ago. Offline
Marcio,
Every project is a unique, one-time endeavor with a specific start and end and lastly a strict budget. Due to a degree of uncertainty in accomplishing the project within that time period it is broken down into various phases from start to end (handover) to facilitate better organizational control. Collectively, these various phases involved to successfully carry out the project is called project life cycle.
If you need more information please use google search engine.
Naveen
Rey Basadre
User offline. Last seen 15 years 49 weeks ago. Offline
Guess:
Project life cycle = start & end of project
