First Update P6 Schedule.
10 replies [Last post]
Shahzad Ahmad
User offline. Last seen 14 years 39 weeks ago. Offline
Dear All
I need to confirm beofre making any mistake to update my Schedule.
i have made a simple Schedule without resource .
all activity are Task depant..
Activity type : fixed Duration & units.
Duration type is: duration.
i want to update based on my Physical % which is i am obtaing thro my progress mesurement sheet.
what i am going to do is i will tick Actual start date and putting physical % ... after that press F9 to see the result.
Do i need to change Duration type before update?
Do i need to change remaing duration while putting Physical % say 10%...
Please advise me in simple way to avoid confussion.
Shahzad
Shahzad Ahmad
Hi Alex
Could yoy please advise me Calculation tab...
what are the changes are required for Manually updating.
Based on Physical %
"how to set aotu compute actual setting" i wan to turn off it.
it is showing tick in my P6 and deactivate...
my schedule is without resource.
Reg.
shahzad
Alex Wong
User offline. Last seen 11 years 5 weeks ago. Offline
Groups: TILOS
Abeer
2 possible cause of double the duration
1 is assoicated with Resource loading calculation and Activity type
2 is project setting
There are 2 options when you set up your project
1. Remaining Duration = Original Duration + Actual Duration
2. Remaining Duration = Original Duration - Acutal Duration
HTH
Alex
mimoune djouallah
User offline. Last seen 4 years 40 weeks ago. Offline
yes, i think original duration must each time be revised using the actual trend, for example:
activity : excavation 1000 m3
Expected productivity : 100 M3/ day then
Original duration OD = 1000/100 = 10 DAYS
when the activity begin you find after let’s say 1 week, that the actual productivity is 50 M3/ DAY thus you will have to change OD according to your actual trend.
OD = 1000/50 = 20 DAY
RD = 20- 7 = 13 DAYS
Physical % complete = 7*50/1000 = 35 %
of course you must keep a baseline before doing anything
HTH
MIMOUNE
Shahzad Ahmad
ANOON
yes my friend your advise is valid.
i allready assign base line...even i have kept one exported files for any bad luck....
Shahzad
Abeer Mahmoud
User offline. Last seen 7 years 45 weeks ago. Offline
Hi Alex,
Did you mean by (3. Update any revised duration) that I revised original duration?
And kindly note that when I made schedule I noticed that for activities which was started and not finished yet the duration at compilation was duplicated I wonder why?
Abeer
Anoon Iimos
User offline. Last seen 2 years 15 weeks ago. Offline
I may suggest to establish the baseline schedule first before making any update.
Alex Wong
Groups: TILOS
Hi Shahzad
If that is the case then I will recommend the sequency of update
1. Update activity is already finished with a actual finish and actual start date
2. Update activity is start but not finish with a actual start date and Physical % complete and Remaining Duration
4. Reschedule the data date to the update data date
HTH
ALex
Shahzad Ahmad
HI ALEX
% complete type is "Physical"
1. Manual Update
shahzad
Shahzad Ahmad
HI ALEX.
Thanks now i understand i have to put Physicasl % complete and remaining duration.
( for activity which is under progress)
my doubt was that i have to put only phy.% complte not remaining duration. ( as we use to do in P3)
Thanks for your advise.
Reg.
shahzad
Alex Wong
Groups: TILOS
Question for u
What is the % Complete type
And how you want to drive your remaining duration.
1. Base on Physcial progress
2. Manual Update
3. 0/100 rule
This will affect the forecast finish date of your schedule
HTH
Alex
