Global change - Activty ID
Naveen Subbaiah
User offline. Last seen 15 years 14 weeks ago. Offline
Hello people,
Can somebody suggest a method to change the first 4 characters in an activity ID using global change ? I am using P3e 4.1
Thanx in advance
Naveen
Select the first activity ID, Select Edit-Replace and type in the characters that you wish to change.
Dieter Wambach
User offline. Last seen 8 years 22 weeks ago. Offline
Hi Naveen
after you extracted the not used values, try
activity id = "abcd" & activity id to add the prefix "abcd"
How to enter "abcd"?
You click on custom in the selection window. Now you may enter any string.
Naveen Subbaiah
Hi Dieter,
Thanx 4 ur response. The substring funtion is helping me only in extracting the characters from the activty ID & not changing it. For exapmple, my activity ID’s are such as UTII-WWTC-0025, UTII-FG-0010 etc., Now in all these, I want to change UTII to UT2. The substring function is only extracting the first four character UTII !!
Naveen
Dieter Wambach
Hi Naveen,
you can use the substring function of global change. It’s well described in the Help-Function - search, then enter "substring". But I’m not sure if this parameter already existed in 4.1.
