Reason for the change FF>TF?
Shah. HB
User offline. Last seen 1 year 25 weeks ago. Offline
Hi to all
I checked a schedule and i found for an activity FF [Free Float]
is greater than TF [Total Float] but in general FF lesser than Total float.
Is there any reason for the change in the condition?
Shah. HB
Many thanks Umar & Anwar
I got the solution for the raised query
Umer Mehmood
User offline. Last seen 3 years 2 weeks ago. Offline
some times in this problem happen when you changed your calculation mode preference , especially when open ended activities are consider critical while scheduling
Hope this will help
Best REGARDS
UMER MEHMOOD
ABU DHABI
muhammad anwar
User offline. Last seen 4 years 47 weeks ago. Offline
Groups: TILOS
Shahul,
If there is a must finish by constraint or mandatory finish pushing end earlier than what it should be will result in FF>TF. Check for the contraints and project finish date at project setting level.
Hope this will solve the problem.
regards
Muhammad
