Importing Budgeted Labour Unit
Susan Young
User offline. Last seen 12 years 41 weeks ago. Offline
Hello Everybody,
I have an issue with importing Budgeted Labour units.
In my schedule I have Budgeted Labour units currently defiend in a UDF column. I am trying to export it in Excel and then re-import the values as Budgeted Labour Units.. (I have already assigned a resource to the activities).
However it doesnt work.
Any suggestions would be very helpful.
Sue
Arnold Puy
User offline. Last seen 10 years 20 weeks ago. Offline
Hi Susan,
You have two option to perform the Resource Loading:
Export it to Excel with two "Export Type" e.g. Activities & Resource Assignments.
1. Under Activities include the UDF in the Selected Option.
2. Under Resource Assignments include the "Budgeted Units" in the Selected Option.
Or you can perform a Global Change, however your UDF must be under the "Activity Resource Assignments" Fields. and the Parameters should look like this:
Where UDF Title "is not equal" (Blank)
Then Budgeted Labor Units " = " UDF Value
Note: Blank means "No Value" at all.
Otherwise, if it ok for you to send the .xer file to primavera6@live.com and I will fix it for you.
Arnold
Izam Zakaria
User offline. Last seen 8 years 28 weeks ago. Offline
Sue,
Use resource resourcement option then upload your BQ onto ’Budgeted Units(h)column. Ensure the resource have beed assigned.
