Loading Schedule with Maanhours
6 replies [Last post]
SM PUM
User offline. Last seen 10 years 14 weeks ago. Offline
HEllo
For our client we need schdules uploaded with manhours (Not Decipline wise).I am confused that when we talk about manhours for aa certain activity then does it means that the this value of manhours is for each decipline or it is collective.For Example
In Blinding concrete=6 Mhr/Cu.m
Does it mean 6 Mhs for Concrete Mixer,6 for mason,6 for mason helper,6 for carpenter etc....or
it is sum of manhours for each decipline?
In above example I will say that each resource will work 6 hours to pour 1 Cu.m of blinding concrete??Is it correct statement?
Ahmet Tuter
User offline. Last seen 3 years 2 weeks ago. Offline
I would definitely say that 6 mh means the total of all of the manhours going into pouring the concrete.
Clint Marquez
User offline. Last seen 7 years 25 weeks ago. Offline
@SM - You need also to visualize the quantities of each activities.
Like on your example,
1cu.m of blinding concrete (qty) = 6mhr/cu (prod.rate)
> Actually, 1-cu.m of concrete can be done in less than an hour, especially if the area to be poured is quitely open and spacious.
> @ 6mhrs/cu. m- you can do assigning 6-workers for just an hour of work to complete this activity.
Thanks.
Clint Marquez
Thanks.
User offline. Last seen 37 weeks 3 days ago. Offline
Vlad,
I understand your point and the illustration you see was just an EXAMPLE of how to define the term "MAN HOUR" in the productivity.
I wouldn't call it productivity rate.
The work will not be accelerated if we will add helpers to this crew.
Concrete Mixer operator = 1 hr
mason = 2 hrs
mason helper = 2hrs
carpenter = 1 hr
The sum of hrs they work = 6 man hrs
means 6 man hours for 1 cu m of blinding is the productivity rate.
