Budgeted Quantity (with Different Cost Category)
6 replies [Last post]
Jun Gallardo
User offline. Last seen 8 years 11 weeks ago. Offline
Hello everyone.
I made a schedule that is resource loaded. My resources include Material and Manpower. Cost Categories are assigned with Material as M and Manpower as L. Normally, adding a new column for BUDGETED QUANTITY in the layout sum up both the quantities of the Material and Manpower resources. My problem is how to add a new column separating both the quantity of the material and that of the labor. I know this is possible in the tabular reports but I want it to be presented in the layout.
Regards.
JUN
Jun Gallardo
Dear Ferdinand,
Thank you. It worked.
Ferdinand U.
User offline. Last seen 6 years 34 weeks ago. Offline
Create Data Custom: Assign BQL-Labor BQ & BQM-Mat’l BQ
for Manpower
if: CAT eq L
then: BQL eq BQ (or BC if Cost)
for Material
if: CAT eq M
then: BQM eq BQ (or BC if Cost)
Jun Gallardo
Mr. Iimos,
Yes, I know how to use the Global Change, but my main problem is how to provide logic to it applicable to what I need. I tried using the logic for Cost Category but failed. I even filtered first the schedule based on resources containing Cost Cat. of "M" and "L" but was unsuccessful. More help plss....
Anoon Iimos
User offline. Last seen 2 years 15 weeks ago. Offline
first go to Data, Custom Data Items, create your items, then play with global change
Jun Gallardo
Anoon,
Maybe yes, but I tried doing the global change but was unsuccessful after a series of trials. Can you please provide me more details on how to execute your suggestion.
Regards.
Jun
Anoon Iimos
if I remember correctly, I think you can use custom data items and make some global changes to suit what you need.
