Automatic Activity ID
9 replies [Last post]
Aymen BEN YOUSSEF
User offline. Last seen 10 years 34 weeks ago. Offline
Hi everybody,
Is it possible in P3 to give automatic activity ID according to WBS for exemple, I checked in activity codes but I can’t find a solution.
Thanks for your collaboration,
Farid Arab
User offline. Last seen 7 years 12 weeks ago. Offline
there is a method that I present it here.
do following steps
1)at first rename your activity Ids from 1 to ....
2)then go to global change and clik add
3)if "ACT" "GT" "0" then
"ACT" "EQ" "WBS" "&" "ACT"
then click Run
That’s it all
in case of that you have to change a large number of activity ids you can import your file to excel then change it and again import it to p3. in this case the whole process takes about 3 minutes
Rick Aquino
User offline. Last seen 14 years 31 weeks ago. Offline
Hi Arnold,
Yes i’m talking to activity ID, THANK YOU again
my two cents.
Rick
Arnold Puy
User offline. Last seen 10 years 19 weeks ago. Offline
Hi Rick,
If you are talking about the Activity ID of the Activity Name then Go to Project Detail --> Defaults Tab --> Auto-numbering Defaults:
Activity ID Prefix = FO000 up to 20 Alpha-Numerical
Activity ID Suffix = must be between 0 to 999999
However, you cannot input 0 first then followed by 1, instead 1 followed by 0
Increment = 1, 2, 3......10 depending on your requirements
Do not forget to mark the checkbox next to "Increment Activity ID based on selected activity.
HTH
Arnold
Rick Aquino
Hi Arnold,
How about in P6, How can set-up the the id?
Arnold Puy
You’re Welcome Ben..
Aymen BEN YOUSSEF
Mr Arnold,
Thank you very much for this precious informations, this is what I was looking for, this tip will help me so much for my next schedule.
Arnold Puy
Hi Ben,
You are talking about the SUBP (Sub-Project) from Activity Codes under Activity ID. Well, You must create by your own. First you have to create a Project group. You can also do this without creating project group. Let say Foundation, your prefix Act ID FO & then followed by 0010. So your Act ID became FO0010.
If you will go to Activity Codes --> Activity ID --> Codes, "Name" you can rename, "Lenght" depend on you 2,3,4 whatever, when done tick refresh, all Activity ID with Prefix FO will be under the Foundation. Under Value, you can find out FO will come out automatically then you can name under Description as Foundation.
Now, you can use this Codes to a certain level and assign this to your activities. Try this exercise..
HTH.
Arnold
Aymen BEN YOUSSEF
Thank you Albert for answering me, but what I need is to put for example two letters at the starting of the activity id according to certain logic for example WBS, Department, Responsibility...
In activity code there’s some settings about activity id but I don’t understand their utility.
Albert Balogo
Hi Ben,
For P3 Programme its always requiring your basis for activity ID, So meaning you need to encode the first activity ID then press arrow down. if you want to change the setting go to tools, option, activity inserting then change the default number.
