GLOBAL CHANGE
likaa likaa
User offline. Last seen 14 years 37 weeks ago. Offline
HI,
I WONDER ANY BODY KNOW CAN HELP ME TO DELET THE FIRST 2 CHARICTER FROM ID ACTIVITY FOR THE WHOLE PROJECT.
THANKS.
LIKAA
Ronald Romero
User offline. Last seen 1 year 44 weeks ago. Offline
Likaa,
You can also use other string function like SS and SUBTR
try in the then statement ACT EQ SS(ACT,3,8), this will do as the one posted by Arthur. Try it.
Ronnie
Alex Wong
User offline. Last seen 12 years 13 weeks ago. Offline
Groups: TILOS
Gents
When you add additional digit is fine, but when you delete digit from existing schedule you need to be careful of "Duplicated" activity Id
HTH
Alex
Joseph Erwin Carg...
User offline. Last seen 8 years 10 weeks ago. Offline
If you want to delete it manualy convert your project first into exclusive access then you can delete or change your activity ad or if you want you can export it to excel then edit it.
joseph
Arthur Godbeer
User offline. Last seen 15 years 49 weeks ago. Offline
See pages 350/351 of the manual for general info on doing this type of thing. I think there is also a tech bulletin on this exact requirement.
In the "Then" part of Global Change, use ACT EQ RIGHT(ACT,8) This should work for any length of Id. (If what remains is purely numeric, it will be treated as such and will be right-justified. There is a way of removing leading blanks for display purposes only. I’d have to look up how to do that.)
Of course, as always, do a "Trial run"!
