Techniques for Deciding Duration of Activites
12 replies [Last post]
Vijayendra Surve
User offline. Last seen 12 years 6 weeks ago. Offline
sir,
Besides experiance is there any technique to fix duration of activites for activties of internal finishing & MEP Services.
John Cornish
User offline. Last seen 11 years 32 weeks ago. Offline
Hi All,
The new release of X-Pert (release 3.5) from Micro Planning International Ltd now offers Pert Estimating of durations, eg Pessimistic, Most Likely and Optimistic and offers a calculated value - based on those three.
You can run analysis, of the whole project, with any of the duration estimates uniquely for the three different duration values.
So you can run a truly optimistic or pessimistic schedule
and even compare the results of those schedules by putting one into an archive.
Great way to get a sense of the uncertainty in your project. Great way to develop best case and worst case scenarios.
John
ashraf alawady
User offline. Last seen 10 years 44 weeks ago. Offline
Simply, as stated previously,
Duration required = Total mandays required/ men per day
Total mandays = Total quantity/production rate
Andrew Dick
User offline. Last seen 9 years 28 weeks ago. Offline
That’s the one thanks Chris.
Andy
Chris Oggham
User offline. Last seen 10 years 31 weeks ago. Offline
Hi Guys,
I’ve played around with the link that Andy supplied to PERT information, and I think the link below takes us to the information he found.
PERT link
Chris Oggham
Shaiju Thomas
User offline. Last seen 10 years 23 weeks ago. Offline
Hi guyz,
Check this classic method.comments are awaited;
Men per day should be determined from the following two conditions;
1. Space restriction
2. Overall time restriction
A D
User offline. Last seen 4 years 38 weeks ago. Offline
The Link mentioned for PERT is not working.
Thats only description of theoretical stuff or its a technical paper.
Will u plz post it again.
Andrew Dick
How about taking 3 of your estimates and doing a simple PERT analysis on them.
See This >>> PERT description.
This is essentially the basis for Monte Carlo analysis, but you can use it as a tie breaker on individual estimates for a specific activity
Andy
Oliver Melling
User offline. Last seen 5 years 44 weeks ago. Offline
Groups: The GrapeVine
Talk to the people who have experience of doing the work, talk to the estimator on the job and always have an updated OBS of the available resource.
Daniel Limson
User offline. Last seen 6 years 1 week ago. Offline
Other factors you need to consider:
Is the programme time driven or resource driven.
There are some projects (i.e. offshore projects) which are resource driven, it means you have limited resources usually based on the number of beds or accommodation they can provide offshore. In this case, the duration will be dictated by the number of resources you have.
On the other hand, Time driven programme means you have unlimited number of resources and the only constraint is space. You can breakdown the task into multiple activities and assign multiple resources or gangs to complete the task given. However, there are some task which are progressive in nature. It means only one gang can be assigned to complete the task progressing from one end to the other.(i.e. Roofing).
Daniel
Anoon Iimos
User offline. Last seen 3 years 28 weeks ago. Offline
don’t forget the location and the conditions! is the Project in Iraq? is it under water or in the middle of the desert? Determining durations of activities is like betting in a lottery!
Actually for most activities durations shall be calculated by PM software and not entered manually.
Duration shall be calculated basing on activity type, quantity of work to be done (activity volume), assigned resource types and quantities, and resource assignment productivity norms (production rates).
Resources can be assigned manually or chosen by the software if project planner assigned not individual resources but resource skills. In the last case activity duration can be calculated only in the levelling process because resources may have the same skills but different productivities.
Daniel Limson
Interesting subject. There is no real or special technique for deciding duration of an activity, only a lot of common sense.
To decide or to define the duration of an activity, you need to consider the following factors:
1st - Production rates and the resources availability in the market. (The level of skill will vary from one country to another.)
2nd - The quantity of work involved on a given task.
3rd - Space ( i.e. Is there enough space to put 30 men to work in the same area)
4th - Time ( Working hours per day)
Knowing all these factors, you can inteligently decide and predict the duration of a given task. Not easy when you are working on a big project with thousands of activities.
