Importing XML file into Asta
amir azadi
User offline. Last seen 9 years 2 weeks ago. Offline
i tried to import a  XML file to Asta, for some reason Asta Split  whatever task longer than 4 days into  several new tasks and roll it up under one task. Is there any way that i can stop this, is there any option in Asta that limits the maximum duration of one Activity?
With Thanks
User offline. Last seen 28 weeks 1 day ago. Offline
Hi Amir
I never seem to have any problem importing Microsoft xml files into Asta - it is probably something in the source file that is causing the split.
You can try lining up the split tasks and use the Split/Join function to join them into a single task.
Mike T.
