Activity Codes - Project
Deepak Jain
User offline. Last seen 11 years 15 weeks ago. Offline
Hi all,
What would be the quickest way (excel import etc..) of creating a Activity Code - Project level code dictionary in P6v7 comprising around 500 elements ?
Thanks in advance,
Deepak
User offline. Last seen 23 weeks 1 day ago. Offline
Deepak,
You need to install SDK first on your machine where Primavera is installed. It is an option that can select when installing Primavera (CD1). Once installed you can use excel SDK to set Project Activity Code.
Deepak Jain
Thanks again Rodel. Could you please explain how to configure Excel SDK to have this import functionality ?
Deepak,
If your task is to define activity codes then you need excel SDK otherwise you need to do it manually.
Deepak Jain
Thanks Rodel. Your solution seems to be valid only when activity coding is defined and you want to assign it at Activity level. Apparently, I need a solution to create this coding dictionary (>500 coding elements) before it’s assigned. The access path would be
Enterprise > Activity Codes > Project
You can built this manually, but i can’t figure out how to import it from excel..
Deepak,
If you can identify the activity by filter or sorting then Ctrl+e (fill function) is enough but if not then excel Export/Import function might be appropriate.
