Problem with the arrangement of Levels in Resources
7 replies [Last post]
Anbin Ponnith
User offline. Last seen 9 years 11 weeks ago. Offline
Dear All,
In P6 I have a problem in getting resources sorted in exact levels as in the BOQ entered.
I have typed the resouce dictionary as in the BOQ sorted in levels and assigned for the activities.Now when I export the project and open in another system my sorted levels are getting changed automatically.
The Resource ids are in the ascending order.But even the Sort by resource id ascending does not help.
Its correct only in the source system.Its getting correct only if we move it mannually in P6.Could any one help me in this issue.
With Thanks & Regards,
Anbin
Anbin Ponnith
Dear Rodel,
Thanks for helping in this issue..
regards,
Anbin
Anbin Ponnith
Dear Rodel,
Thanks for the reply,
Actually I don’t know to insert the snap shot in the inline text message.Shall I send it to your email id as a jpg file.
Anbin ponnith
User offline. Last seen 20 weeks 5 days ago. Offline
Anbin,
I’m not sure where the problem is until I can see the snapshot or screen dump of both scenarios. I will send you a PM.
Anbin Ponnith
Dear Rodel,
I imported on the same basis using update existing for all.
Also I am using Stand alone.
But Still the problem exists.
Anbin Ponnith
Anbin,
Does the resource already exist in the new system? When you import the XER, did you select update existing for resource, resource code, Roles etc...?
Another problem that you might encounter and using multi-user environment (network) and multiple users using same layout (without restriction applied) and someone change the arrangement, layout will be change from last user who save the layout.
Anbin Ponnith
Dear Rodel,
Thanks for the Reply.
I saved the layout in the resource assignment sheet and imported to another system.But I am not able to get the source level.the order gets changed anyway.
Where Am I going Wrong?
Anbin
Anbin,
You can export also the layout from the source and import on the new system. That should solve your problem.
