Plan Progress vs Actual Progress
Irfan Khan
User offline. Last seen 10 weeks 5 days ago. Offline
What is the difference between Plan Progress vs Actual Progress & how can calculate Variance between this.
thanks.....
Balaji Surendiran
User offline. Last seen 14 years 12 weeks ago. Offline
% Planned : % of works planned to be done (from baseline)
% Actual: % of actual work happened (you need to update)
You can insert both the columns and variance as Rodel already explained.
Balaji
User offline. Last seen 2 weeks 5 days ago. Offline
Irfan,
Plan Progress is taken from your baseline. If you don’t have baseline assigned by default P6 use current Project. Actual Progress is the % complete that you enter every cut-off date before running schedule (F9) on the new Data Date or status date. You can get the variance of the two by showing Column-> Durations-> Variance - Project Duration or Variance – Project Start Date or Variance – Project Finish Date.
