Filtering and export to excel
Christian Viddal
User offline. Last seen 14 years 46 weeks ago. Offline
Was wondering if someone could help me with a task regarding exporting.
I want to filter out all the activties due in one week and export it to excel together with all colums. I am sitting in Release:6.2(terminal server)
Appreciate if someone could explain it step by step as I have never done exporing to excel before but I have heard it is possible.
Christian
Arnold Puy
User offline. Last seen 10 years 20 weeks ago. Offline
You are welcome..
Christian Viddal
Perfect, thanks a lot!
Arnold Puy
Hi Christian,
You can simply go to Project Menu --> Resource Assignments, try to display all the columns you required by simply right click --> Columns --> Customize. To filter the One (1) week look-ahead try these parameters:
(Any of the following)
Where:      Start “is within range of” DD DD+1WK
Or:      Remaining Early Start “is within range of” DD DD+1WK
When done, go to Edit --> Select All and then right click copy and paste it to Excel sheet.
Or you may try to go to File --> Export --> Spreadsheet - (XLS) and follow the window wizard.
Arnold
