A tricky problem wit hP6.2
Vinod Ramaswamy
User offline. Last seen 9 years 3 weeks ago. Offline
Hi all, I have a tricky problem with Primavera Project Management V 6.2
I am trying to export my file to excel coz I need to pull the data for presentation on a webpage. I have the code to pull relevant data for that but P6 wont export all data to excel. It does not export the WBS Summary task to excel. It exports all the other only the Summaries are left out & I can’t present the page well without a summary. Any help with this?
Thanks in advance
Izam Zakaria
User offline. Last seen 8 years 28 weeks ago. Offline
Vinod...
what does "neways" means? I just found newel which means winding staircase. i don’t understand
Duy Huynh
User offline. Last seen 15 years 14 weeks ago. Offline
If you want only data in Activity Table, just select all the column needed and Ctrl-A then go to Excel Ctrl-V.
Duy.
Arnold Puy
User offline. Last seen 10 years 20 weeks ago. Offline
Hi Izam,
Actually, It’s anyway.
Hi Vinod,
Try to use the "Report" just like what Mr. Dieter said or just simply copy the data you needed by using CTRL+C and paste it to Excel using CTRL+V just like what Mr. Duy mentioned.
Arnold
Vinod Ramaswamy
:) coz = because not cosy. neways I checked & gave up so i opted for a manual edit of the wbs codes :)
Dieter Wambach
User offline. Last seen 8 years 9 weeks ago. Offline
Vinod
We need this function, so I just tested. WBS Summary are exported to Excel.
Check if you activated a filter.
Sorry: "coz". I just found cozy=cosy which means warm, comfortable. I don’t understand....
