AVAA0-2005-1
13 replies [Last post]
Rick Gulewich
User offline. Last seen 16 years 21 weeks ago. Offline
I’m trying to import EPS codes from one project to another in PM6.1 (~4200 activies). But I get and AVAA0-2005-1 error. Any ideas? I have contacted primavera but they have no ideas.
Dieter Wambach
User offline. Last seen 8 years 23 weeks ago. Offline
Delete in general is done by a delete flag (last column).
I just tried Exp --> Imp: It does work. but the records which I deleted were not touched in P6. So use the delete flag.
Is there any entry in the event log?. Maybe you’ll start the trace (under edit --> user preferences).
More and more I assume that your pc is the reason.
What happens if you’ll log into P6 from a different pc with your user?
Rick Gulewich
I tried exporting file then deleting all activities execpt one the reimport file. But I get same problem
Dieter Wambach
I don’t know the real reason. but next steps for me would be:
1. Export an Excel file (6.1 doesn’t know xml-format), modify e.g. an activity name and import it again.
2. If 1. works then export that specific format, if not continue with 3
3. Compare your Primavera user settings with those of a colleague where it works (currency)
4. Compare the settings of your pc with one of a colleague where it works: regional settings, ...
Rick Gulewich
It has not worked for me - but others in my group have used this process successfully.
I can import a new project
I will check on virtual memeory
Dieter Wambach
It seems that the wizzard didn’t come to an end and the import didn’t start. I assume some access rights are missing while creating a table.
I don’t know this code and since I don’t work for Primavera there is no chance for me to get further information. So let’s approach step by step.
Did it ever work?
Can you create a new project in P6?
Sufficient of memory inclusive virtual memory?
Rick Gulewich
* EXCEPTION REPORT *
Date: 27-Feb-09
Executable: PM.exe
Application: Primavera Project Management
Event Code: AVAA0-2005-1
Message:
Access violation at address 00C36F5F in module ’PM.exe’.
Read of address 00000090
Context:
1: TfrmWizImport.RunImportWizard
2: TfrmMain.actHomeExecute
3: TfrmMain.actFileImportExecute
4: TfrmEPS.mnuOpenProjectClick
5: ConsoleUtil.GetExitCodeProcess
6: ConsoleUtil.CreateProcess
7:
8:
9:
10:
Detail:
Type: EAccessViolation
Object Type: TCUltraButton
Components
ORI: ORI Win32 #
ORI/DB: PMDB,0601.0011.0001.0001
IMG: IMG Win32 #1000
System Info
Username: rickg Hostname: DT54713
OS Version: Windows NT ver 5.1, build 2600, Service Pack 3 (Intel Pentium)
Dieter Wambach
Did it ever work?
Can you publish the content of the three detailed windows that you can see under "more"?
Rick Gulewich
It does not mod format. Others can import using the same process
Dieter Wambach
I don’t know VLOOKUP. check if it modifies any format.
Did it ever work?
Rick Gulewich
Yes I export from the previous month end schedule and then export the current month end schedule I add the codes to the current month end schedule via VLOOKUP and then reimport the current month end excel sheet.
Dieter Wambach
Did you first export to Excel, then import using the same structure?
XLS or xml (Excel 2007)?
Rick Gulewich
Import from excel
Dieter Wambach
Rick
This message is within a small window. If you’ll push "More" you’ll get more information and can copy it.
The size is not relevant. How do import?
Sorry, no answer, just questions.
