Activity limit exceeded
6 replies [Last post]
José Arturo Varga...
User offline. Last seen 15 years 2 weeks ago. Offline
Hello, I’m new planning and I did force to install Vista in the laptop, I have an old project that charges succesfully in XP, but in Vista shows: "Activity limit exceeded", I think maybe is a setup problem, because demo projects loads fine.
Thanks and sorry for my bad english.
Finally I fix the problem, I ran Windows Update, reinstall P3 and voila!!! works great.
Thanks for your time :)
Safak Vural
User offline. Last seen 3 years 45 weeks ago. Offline
Dear Arturo,
Please try to run P3 fix on the project. Mayebe some of the files have been corrupted. It is in the programme directory named as PFXW.EXE.
I hope that is the problem and the solution. I am usnig P3 both on XP and VISTA (VISTA if I work at home :)). I never encounter such problems. I will look when I return home.
Safak
I tried in mode administrator, compatibility with Windows 95, 98, 2000 and XP but the problem are the same :(
Ferdinand U.
User offline. Last seen 6 years 34 weeks ago. Offline
not sure with this, but try to run in compatibililty mode and as administrator
The version installed in XP and Vista is the same
Ferdinand U.
i think you are using demo p3 version
