Export data into Excel !
Deepak Jain
User offline. Last seen 11 years 15 weeks ago. Offline
Hi all,
While exporting data to excel, P3 usually generates some un-necessary columns containing some random characters. Any ideas to get rid of this ? n any method to have custom defined column titles..
Deepak
Gün Göksu
User offline. Last seen 2 years 49 weeks ago. Offline
Deepak,
Please copy paste the first 3 of 4 lines of the export you get and say you have the random characters. If you havent solved the problem yet.
I have never seen P3 output random characters; there must be a reason.
also as previously said: looking at the export "Contents of list" just before an export will and must give you an idea.
otherwise please send/post here an example of the export file. especially the first 3 lines.
Gün.
Hashim Muhammud
User offline. Last seen 13 years 10 hours ago. Offline
if you can let us know some of those unneccessary characters then may be we could help you.
And regarding giving custom names for columns, as far as i know its not possible.
bye
Christian Adrian ...
User offline. Last seen 5 years 47 weeks ago. Offline
You can try checking the data field under the Export>Contents of List... there could be some data fields which are unneccesary for exporting...
HTH...
Jose Frade
User offline. Last seen 4 years 15 weeks ago. Offline
It never happened to me.
Try using RA to get data out of the database - and even changing the samples you can extract exactly what U are looking for.
May be not a big help
BR
JMFrade
