Primavera 6
Timmanna Huilgol
User offline. Last seen 12 years 1 day ago. Offline
Groups: GPC Qatar
how to import activity codes & code details from excel to p6
sachin sangai
User offline. Last seen 10 years 5 weeks ago. Offline
Sorry Walshy it doesnt work.
Becasue the Activity codes are not defined, it gives an error while u import.
Thanks Arnold for the help PATTLNK_632006_536xerFileParser&Builder.xls works just fine.
Sachin
Neal Walsh
User offline. Last seen 4 years 36 weeks ago. Offline
Timmanna,
An easy way of doing this (if you have one) is to export a programme with Activity Codes to Excel. The result will show you what format the Excel needs to be in to allow Primavera to understand it. Then, delete the Activity codes and replace with the ones you need before importing into P6. I have done this successfully with Activity ID’s / Names and dates / durations etc....but not with Activity coes, although in theory it should work. I know Primavera requires the ’ at the beginning of each cell data.
Good luck
Walshy
sachin sangai
hi Arnold
can u elaborate more on how to use PATTLNK_632006_536-xerFileParser&Builder or guide us to a place we can find more information on this because i see for many quarries this seems to be the answer.
Sachin
Arnold Puy
User offline. Last seen 10 years 20 weeks ago. Offline
Hi Timmanna,
You have Three ways to perform with:
1. You need to have SDK (Dictionary6x.xls).
2. You can use the PATTLNK_632006_536-xerFileParser&Builder.
3. You can also link or connect to the database using MS Access or MS Excel.
Arnold
