Multiple Project Scheduling
6 replies [Last post]
António Faria
User offline. Last seen 10 years 5 weeks ago. Offline
My question is as simples as this: How can I visualize 2 projects in Primavera P6.2?
I opened two projects (selected both and after Ctrl-O) and I was expecting that Primavera opened both projects in the layout on "Activities View".
AF
António Faria
Now I got it. :) Now I’m seeing two projects in the Activities Workspace.
But I was thinking in two subprojects, or more subprojects of a master project. If it was like so, I only need to open one project, export one or guaranty one time all subprojects definitions (calendar, baseline, ....). Maybe I express myself wrongly or maybe this is the only way to work with subprojects.
Having two projects open, or more projects open, it’s more difficult to work than one with subprojects.
AF
Dieter Wambach
User offline. Last seen 8 years 6 weeks ago. Offline
António
Screenshots or file attachments can’t be sent within the forum.
To open two projects: File --> Open --> select and mark (using ctrl-key) the two projects --> button "open"
G&S: Access as shown before --> if you’ll klick onto "wbs" all other possibilities appear --> select "project" --> move cursor one line below --> klick onto that empty field --> select what you need.
Appropriate screenshots and more explanation you’ll find in the RefManual (PMRefMan.pdf).
António Faria
OK Dieter.
But it’s possible to see two projects at the same time? Could you give a example how to configure Group&Sort to display two projects?
When I open Group&Sort window, with both projects opened, it shows Group By: WBS level 1, and after WBS level 2 (grey), WBS level 3 (grey), ..., WBS level 20. But this only shows default project in "Activity Workspace".
It’s possible to add snapshots in posts?
Dieter Wambach
António
It is not possible to show two projects in different windows with different g&s.
António Faria
What I want to do is see two projects opened in two windows showing their activities inside the "Activities Workspace".
I was trying to change Group&Sort definitions, but the changes are only affecting the default project. Furthermore, I could not see how could I select different "Group by" options and apply to each project.
As an example:
Project
|Sub-Project 1 |
| Activity 1.1 |
| Activity 1.2 |
|Sub-Project 2 |
| Activity 2.1 |
| Activity 2.2 |
Dieter Wambach
António
I don’t really understand your question.
In P6 you select projects, then open them all. No restriction on quantity.
By group & srt you can group the data by all existing criteria - codes, project, etc. Move cursor into table area --> right mouse button --> group & sort
