P3 Printing Problem
8 replies [Last post]
Christopher Nicolas
User offline. Last seen 16 years 7 weeks ago. Offline
Print problem
I am having problems with P3.1 When I print a programme to Adobe which includes a bitmap logo P3.1 stalls and doesn’t produce the PDF - however without the bitmap logo the programme prints to PDF fine. I have tried P6 and it works fine also.
I know about the print icon way to print PDF’s but this does not help in this situation
I need help urgently!
Arnold Puy
User offline. Last seen 10 years 15 weeks ago. Offline
Hi Alexandre,
You can download P331SrvPk3.exe here:
http://www.projectstatus.com/pub/
HTH.
Arnold
Paul Harris
User offline. Last seen 2 years 8 weeks ago. Offline
Normally one just saves it anywhere on the C drive and execute it. Never seen your problem before!
Paul E Harris
Neeraj Agarkar
User offline. Last seen 6 years 19 weeks ago. Offline
Bitmaps always cause problem with primavera headers / footers. I find that bitmap appears only on alternate pages of printouts.
However, if you convert .bmp or .jpg to .pmt format, the logos appear fine and even work well with Adobe.
Neeraj
Christopher Nicolas
Alphons - You are correct CutePDF works without fail on my personal laptop but we have Adobe on our network at work - I will have to remove and put on Cute instead.
Many Thanks
Alphons Bruns
User offline. Last seen 42 weeks 14 hours ago. Offline
Hello Christopher,
You might like to try Cute PDF, it never gave a problem in my case and gives better pdf than Adobe.
http://www.cutepdf.com/Products/CutePDF/writer.asp
Regards and succes
Alphons
Christopher Nicolas
Paul,
Thanks for your swift reply - I spoke to you a couple of months ago before I departed Australia about purchasing books. I have established Tracey Brunstrom & Hammond in Singapore the Gulf. We have gone into partnership with Confluence (formerly Australian Pacific Projects Internation - APPI). Please see attached.
http://www.confluencepm.com/NewsItem.aspx?id=1254
If you know any senior planners looking for work overseas please don’t hesitate to contact me - I need good people!
Many thanks once again.
Paul Harris
I suggest you never put a logo in P3 or SureTrak or Microsoft Project headers of footers as they always cause issues. Adobe is well known for clashing with P3.
Several possible solutions
1.     You have not loaded the latest Service Pack SP3. Available from my web site under Project Management software
2.     Your path to the schedule is too long of is not 8.3 compliant. You could map a network drive to the P3 file location. All directories should have less than 8 characters without spaces.
3.     You may need to map a new printer port with a short path say C:\P3\P3OUT. Do this in the Printer Properties form.
4.     Use a different pdf writer.
Paul E Harris
Planning and Scheduling Training Manual & Book Publishers, Consulting and Training
www.eh.com.au
