Reading monthly Original budget hours
Saqib Ullah
Luyanda Ndlumbini
Jeff Waldrop
Robert Roy
Tony Wright
Arshman
Stan Remiszewski
GeoVe
JAGAN REDDY MUSUKU
Nick Johnson-Pond
Hi Dieter,
Yes, the software is P3ec. I will check the documentation.
Thanks.
Sanjay
Hi Sanjay
response is a little difficult without knowing the software you use. You speak of a database, so I assume P3e/p5:
One of the P3e-CDs is documentation. There youll find
Documentation\Technical Documentation\Schema Docs\PM50SchemaDiagram.pdf
Now you can use SQL. Easier will be an access via the API.
Hope, this will help.
