Claim Digger (Schedule Comparison Tool)
12 replies [Last post]
Milton Maindonald
User offline. Last seen 15 years 23 weeks ago. Offline
When I run the Claim Digger under the Tools Menu nothing seems to happen. Do I have to do something else prior?
(I’m wanting to identify deleted activities from the plan so they can be removed off our time clock system)
Mohamed Hegab
User offline. Last seen 4 years 22 weeks ago. Offline
Did you try an independent tool such as schedule cracker (www.schedulecracker.com)?  It does the job with very nice reports and features.  They offer it for free 14 day full functional trial.
Milton Maindonald
We’re all up and running.
Very handy accessory!!!
Milton Maindonald
I have hopefully found a fix for the problem in the Primavera KnowledgeBase. (Solution ID: prim42298)
Our IT guy will be looking into the fix ASAP. I’ll let you know.
Thanks again for you input.
James Braghini
User offline. Last seen 14 years 41 weeks ago. Offline
Try giving yourself complete admin rights to the drive where the program is located (i.e. C drive. This includes security and read/wire permissions.
Good luck,
James B.
Milton Maindonald
Have all those. I even downloaded the latest Java files from there web site. Still nothing.
Ahmed Abu El Azm
User offline. Last seen 6 years 32 weeks ago. Offline
I have access - administrator rights - to this folder but what shall I do then?
A D
User offline. Last seen 4 years 37 weeks ago. Offline
To run claim digger, u need to hav full access for following folder:
C:\Program Files\Common Files\Primavera Common\Java
If not, tell ur IT guys to have full access for above folder
Milton Maindonald
Thanks you all for your reply’s but alas, I’m still not having any luck after trying your suggestions. I must have a more deep-seated computer problem.
Patricia Le Clainche
User offline. Last seen 10 years 38 weeks ago. Offline
Hello,
I had in the past the same problem and the solution was as describe by Antonio.
I am not sure (I am not an expert in this matter), but I think it had been solved by a new Oracle version... you might explore this way.
What is sure is that I do not have troubles any more.
Good luck.
Patricia
James Braghini
Make sure to check the string. We have the string correct but the folder was named something else.
Good luck.
James Braghini
António Faria
User offline. Last seen 10 years 12 weeks ago. Offline
It seems like, but if you minimize Primavera or clicking in the "Show Desktop" you will see a new window (Claim Digger).
Select the project that you want to compare, fields to compare and the kind of report.
BR,
AF
Ahmed Abu El Azm
I have the same problem
