Excell function to capture data from a cell of group
S
shiv rao 👤 Member for 18 years 3 months
S
ANDREW , CAN I GET YOUR EMAIL ID .
SO THAT I CAN SEND YOU THE FILE .
RGERDA
SHIV
Andrew Podolny 👤 Member for 21 years 6 months
Use custom function in VBA for this purpose. If you are not familiar with VBA just send to me excel file and I’ll do it. Regards,
Andrew
O
Oliver Melling 👤 Member for 19 years 1 month
If you set the colour manually then you can’t do it. If you make the conditional format for example, so 1 makes the cell red, then you could do a SUMIF or COUNTIF with 1 as the criteria.
S
The Colour will be set manually .
and the value is to be calcualted based on the cell which are red in colour.
Shiv
Z
Zhang Haixiang 👤 Member for 21 years 2 months
it’s impossible to use cell format as criteria in function SUMIF.
how you set the color of a cell? mannually or by conditional format.
O
Click on a RED formatted cell and go ’Format’ ’Conditional Formatting’. The criteria will be there!
S
Oliver thanks for your good try .
We need the condition format as a criteria .
And thats not excepting.
Sumif[A2:A8]"criteria" range.
In the criteria we need to find if a cell is red in colour then we are going to sum the range of values.
But i think we are near to the answer.
Someone there to help us plz.
Shiv Rao
O
Conditional formatting uses a statement to decide if the cell should be RED. Look at the conditional format of a RED cell and use it as part of a SUMIF function.
EViLL1
Dimitrios Theocharidis
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
