P3 Page Set Up
10 replies [Last post]
dennis walker
User offline. Last seen 20 years 28 weeks ago. Offline
Hi Planners
Hoping someone can help me with a minor problem:
On one particular plan that i am curently working on, when I go into the page set up menu the SHOW VISIBLE COLUMNS ONLY BOX is greyed out and I am unable to put a tick in to it for printing purposes can someone advise the reason for this and how to rectify
Dennis
Joe Delamo
User offline. Last seen 14 years 20 weeks ago. Offline
It worked....Thanks for the post
Grant Polatajko
User offline. Last seen 13 years 13 weeks ago. Offline
Thanks Katalin - I had already considered that workaround.
One of my colleagues here actually came up with the solution. It was to force P3 into a reset of this option by dragging the dividing line that separates acitivity columns and bars all the way to the left so no bars are visible. When the dividing line is dragged right again to display the activity columns, the option is available normally again.
Thanks Frank
Katalin Hovanyi
User offline. Last seen 11 years 8 weeks ago. Offline
To go around this problem, try to write 0 width (Format, Columns, Width) for all the columns You don’t want to see (or print).
Grant Polatajko
There is a workaround here but no proper solution. Does anyone know what this problem is?
Grant
MK TSE
User offline. Last seen 5 years 11 weeks ago. Offline
Please check if column and/or bar areas are display on screen. If you have selected Resource profile or curve only, the box is disabled.
Raj Maurya
User offline. Last seen 4 years 7 weeks ago. Offline
Hi! Dennis,
Can you check in your other P3 project file, there "Show visible columns only" is working or not? If not then I think you can load P3 again. But for the time being you can follow Andrew’s suggestion.
Andrew Podolny
User offline. Last seen 2 years 6 weeks ago. Offline
Hi, Dennis!
You can make it even without "Show visible columns only".
According ot P3’s logic if you left unchecked this mark P3 will print out all columns defined in the current layout. So all you’ve to do is to copy current layout to a new one and arrange the columns you want to be printed out.
Best, regards
Andrew
Jaco Stadler
User offline. Last seen 18 years 44 weeks ago. Offline
When you look at the program do you see the columns as well.
If not that may be the problem.
Or maybe you need to run Fix it
dennis walker
Hi Raj
Thanks for your reply
But even after I have ticked Activity columns box the Show Visible Columns only box stays grey
Raj Maurya
Hi! Dennis,
To put tick in "Show visible columns only" first you have to tick "Activity Columns" then only you will be able to tick "Show visible columns only" box.
