Schedule Variance Procedures
Dana Fitkowski
User offline. Last seen 11 years 42 weeks ago. Offline
Hello!
I was wondering if anyone was able to help, our group is looking for any info on writing a procedure for schedule variance reporting. Any examples or samples would be much appreciated.
Dana Fitkowski
Thanks very much Peter, certainly does help us out.
Peter Holroyd
User offline. Last seen 16 weeks 4 days ago. Offline
key data to be derived from the schedule is
1 SPI performance on an accum and period basis of current v baseline programmes - this gives the history then look forward by
2 SPI Index to Completion - this is the improvement required to finish the job on time (assuming you are behind)from which you can see whether it is realistic
3 Print out the top (5 ?) critical paths on the project and make sure they are sensible and everyone knows which are the current activitites on these critical paths
4 then as a test to see if you programme is getting more critical try a Float Trend Analysis graph
5 a simple Principle line would be nice but most software doesn’t support this
Hope this helps
