Database Cleanup - SQLlite - R8.4
Andrew Sargent
User offline. Last seen 5 years 28 weeks ago. Offline
After reaching the 4GB limit on the XE database for the 1000th time I decided to just switch over to SQLlite. I have no reached the point where even my SQLlite database is bloated with POBS and old codes. Can someone tell me how to cleanup my sqllite DB?
User offline. Last seen 3 days 13 hours ago. Offline
there are several thing that you can do
1. Clean the POBS tables in the existing database here is how
Click on start All Programs, Microsoft SQl Server 2005, SLQ Server Management Studio
Authentication: Should be SQL Server Authentication
Login: sa
Password: Prima123Vera
Then click connect
Expand the database folder and click on pmdb$primavera
Then up top select new query
Then type this
delete POBS;
the right click and select execute
now you can close and exit out of sql
2. download this POBS cleaner adn clean every XER file prior to imporing it
http://scheduleanalyzer.com/PurgePOBS.exe
3. You can exort the old projects as xer files save them to a thumb drive, an external hard drive or a network drive then delete these old projects.
4. You can create another database and stsrt to add NEW projects to that database
David Kelly
User offline. Last seen 2 years 44 weeks ago. Offline
SQLite Management Studio. Don't leave home without it.
