P6 on Windows 7
MichaelFuelsC
anwar zeb
olva seselima
Muhammd Muneer
sairam
MARAT BILYALOV
RichTea66
Muneer Muhammad
Manny Onifade
Hunais M J
Thank you so much... all your comments helped a lot..
Ronnel Anthony Celerio
Ronnel;
I am currently running P6.7 under Windows 7 Pro 64 bit.
Installing the SQL server was a bit of a hassle (needed to use 2005 instead of 2008). Was fortunate to have an old Primavera support person to assist - it took 3 hours of direct computer control to accomplish. I do not think you will have the same problems, especially if you use Oracle Express, but give yourself plenty of time and make sure you do it during normal support hours. I went with SQL because of familiarity and the need for multiple databases (no prohibition from Oracle so far, regardless of what some think the license says).
I have not rigorously tested it, but it seems to be working fine. Seems necessary to run the SQL server script to enable Background Jobs - may be a 64 bit bug. Oracle database may not have the same problem/bug/annoyance.
Not sure about the requirement to install Oracle Client. That has not been my situation, though I did see the notice.
My project is small, so no real performance increase seen so far.
Great post Rafael,
In a quick summary:
Feb-2009- P6.2.1 was NOT tested to support the 32 or 64 bit Windows 7
Dec-2009- P6.v7 was tested to support 32 and 64 bit Windows 7 (Note: the 64 bit Windows 7 version requires the 32 bit Oracle client)
Benit.
www.emerald-associates.com
Maybe this can help.
http://knowledgebase.primavera.com/attachment/PATTLNK_342009_1553-Teste…
http://download.oracle.com/docs/cd/E16688_01/Tested_Configurations/Test…
