exporting to excel
sunil kumar
User offline. Last seen 15 years 28 weeks ago. Offline
i am a beginner in p3 .. can anybody pls briefly explain how to export activity ids, activity desc,ES EF,OD RD to EXCEL....
thanx
sunil
Andrew Tan
User offline. Last seen 12 years 20 weeks ago. Offline
If you want to know what to export, use WK1 for export and edit accordingly. Try importing after that.
I will not recommend exporting and importing unless you have a lot of data to amend fast.
I have a excel utility that will extract data like export/import function.
Hannes de Bruyne
User offline. Last seen 2 years 41 weeks ago. Offline
Better use a wk1-File to export (can be extended for reimport)
Sen Moc
User offline. Last seen 19 years 24 weeks ago. Offline
In P3, select Tools/Project Utilities/Export. Then if you don’t want to use the existing export definition file, CLICK MODIFY.
In the Content Tab, select Export/Contents of List. Then choose the items you want to export such as, Act ID, Act Description, ES, EF, etc……..
In the Format Output Tab, Input filename and select file type. Note: the default file location is P3win/P3Out.
In the Selection Tab, provide selection criteria or leave it blank if you want to select all activities.
Finally, Click Run.
Then, in MS Excel open the exported file. Note: the default file location is P3win/P3Out.
Good luck and More Power!
David Andreotti
User offline. Last seen 9 years 16 weeks ago. Offline
Sunil;
Run the export utility in P3. It will take you through the process.
Dave
Steven Oliver
Easiest way is to Cut & Paste
