Can not open file
12 replies [Last post]
george stewart
User offline. Last seen 9 years 37 weeks ago. Offline
File does not show on screen.
I have access to a remote server that holds P3 files. Up on till recently I have been able to open and work on all these files. Now when I open a particular directory, (other directories are OK) I can view the programme files, but not open them. When I open, I can see the process starting in the lower left hand screen,(extracting files, initalising printer)stops the process and then P3 then reverts back from this drive to my C drive. If I have had a programme file open on screen, from another directory this file has then been closed. I can copy the files from this rogue directory to another directory, but they still fail to open.
Other planners on the network have no problem, can any person help.
Many thanks,
George
george stewart
To all,
Many thanks for all the suggestions, reinstalled P3 and problems solved. I have kept a copy of my old P3 and projects to try and figure out the cause. If I solve it I will post.
George
george stewart
Jaco,
Answer Q1 Can see Overview Etc
Answer Q2 If I have P3 open the Message is "Cannot start more than one copy of the specifed program"
If P3 is closed and I double click Lay File, P3 Opens as normal and then starts to try to open the specified file and continues as described previously IE closes at 2nd/3rd opening process.
Answer Q3 Created new user, and process is as answered in Q2
Jaco Stadler
User offline. Last seen 19 years 1 week ago. Offline
Hi George
1) A couple of more Qeustions When you go file open can you see the Overview (Targets etc)(Without opening the file)
2) If you Double click on the Lay file in explorer does it open p3. If no what does it ask for.
3) Have you checked netset. Try and create a different you in Netset.
george stewart
Jaco, Have arranged to reinstall P3 this morning. No restricted access to files. Server speed has not changed.(still fast) Kamran, Copy or Back Up/Restore are functioning in as far as all the files can be seen in Explore, but fail to open. P3 does not show any error message, but as stated starts to go through the opening process and then disappears of the sreen. Regards, George
Jaco Stadler
George
I would suggest reinstall P3.(Sometimes this is easier)
I would also check the access to the files. (Restricted access)
Also have a look at what speed you are connected to the server sometimes this might be a problem.
kamran hazini
User offline. Last seen 13 years 6 weeks ago. Offline
Quote
"I can copy the files from this rogue directory to another directory, but they still fail to open."
Unquote
George, could you please tell us the exact error message that P3 will show you when it fails to open?(if any) I mean the exact way that software responds.
Beside of that, have you tested Copy or Back up/Restore features are functioning for this particular plan?
thanks
kamran
george stewart
Thanks, but done that.
Geo
Daniel Limson
User offline. Last seen 6 years 13 weeks ago. Offline
As you know, P3 has several files, maybe you need to check if all the files/layout are complete. Maybe one of the files have been accidentally deleted or corrupted. you can do this by comparing it to the number of files on another file/project.
Hope this helps.
Daniel
george stewart
Yes,and Yes. tried that. One of the first things I did.
George
Ronald Winter
User offline. Last seen 4 years 32 weeks ago. Offline
I do not know what Primavera Support told you to do. Did you run Primavera’s PFXW.exe program against the schedule to verify and correct for any data errors?
Have you copied the files to your own computer and tried to open them?
george stewart
Many Thanks for the suggestions, I have tried these and also I have tried Primavera Support. They have not been able to help, so far.
George
Dayanidhi Dhandapany
User offline. Last seen 4 years 30 weeks ago. Offline
Hello George,
If everyone in your network is able to open the p3 files then something would be wrong with your access rights, may be you can use anyone of your friend’s user name and pwd(with their permission) to login into your system and try whether you can open those p3 files or not. If it is not resolved may be you can contact p3 dealer or your network administrator for further help.
Cheers!!!
Daya
