i am tring to open the some files of P3,other files are working, and i get an error "Unable to lock target project" what should i do to open these files
19 years 11 months
Member for19 years11 months
Submitted by Stephen Fawcet… on Tue, 2006-04-11 07:22
16 years 3 monthsdelete the reference to the
delete the reference to the target in p3 if you can not do that then
delete the target files from the folder
copy the existing file and give it the name of the project that is the target project
open the project
12 years 6 monthsi have got the solution by
i have got the solution by try and error.just i copied those files which have the problem to another folder and opened without problem.thank you
12 years 6 monthsi have tried to remove the
i have tried to remove the target project but i couldnt again i get error messege "exclusive access denied".
12 years 6 monthsi am tring to open the some
19 years 11 monthsRE: Network problems
Thanks for your help but we have just found the P3 version downloaded is not working properly. Problem now resolved many thanks
23 yearsRE: Network problems
What happens if you unattach the target project ?. Sounds like someone has the target plan open in Exclusive mode
