My recommendation is dont install winXP SP2 at this moment. The SP2 download from window update website been remove by Microsoft quite a while. There is no notice issued why it is removed. (Im not sure now it is available again or not)
21 years 2 months
Member for21 years3 months
Submitted by Gilles Auerbach on Thu, 2004-09-09 04:50
Thanks for your comments. Have solved the problem. Because P3 is a 16 bit programme windows runs it in a virtual machine that is implemented via Autoexec.nt.
I discovered that either Win XP SP 2 or another programme had corrupted the Autoexec.nt file. Once I reinstalled the Autoexec.nt file P3 worked fine.
What concerns me is that if Win XP SP 2 has caused the problem, it may affect other 16 bit programmes.
22 years 10 months
Member for22 years10 months
Submitted by Ronald Winter on Mon, 2004-08-30 19:23
P3 Windows Version 1.0 and P3 DOS (any version) will not run on XP no matter what you try. You can get P3 Windows Version 2 to run under XP but you wont be able to print. It requires P3 Version 3.1 with Service Pack 2 to run P3 normally using your new operating system. Sorry for the bad news.
22 years 9 months
Member for22 years9 months
Submitted by Alexandre Faul… on Mon, 2004-08-30 16:55
23 years 8 monthsRE: Windows XP Service Pack 2
21 years 2 monthsRE: Windows XP Service Pack 2
hello ...
I had the same problem with the install of SP2... but i found a solution...
First, you have to insert your original Windows XP CDROM and to open a DOS Window... Then write in the DOS window
"expand D:i386autoexec.nt_ c:windowssystem32autoexec.nt"
Then make a copy of your file name autoexec.nt which has been created in c:WindowsSystem32 in c:.
Now you have to create a .bat file (create first a txt file and then rename it in.bat). The you write in
"copy c:autoexec.nt c:windowssystem32"
The you have each time to run that bat or to run it automatically at the start of windows...
After it works very well :-)
22 years 9 monthsRE: Windows XP Service Pack 2
I think XP do have a virtual engin to run 16 bit application
What you can do is create a desktop short-cut, select the short cut, right click and select properties and select run in window 98 mode.
22 years 10 monthsRE: Windows XP Service Pack 2
Well, Bill Gates did say that he intended all users to migrate to 32-bit programs.
22 years 5 monthsRE: Windows XP Service Pack 2
Hello,
Did you try to use the compatibility feature in Windows and select an older Windows such as 98 or NT4?
