I would like to write Quality and Safety Policies for my company. Therfore, Should I or my company be ISO certified to write and implement such policies??? Please advise.
Your response highly appreciated.
12 years 9 months
Member for12 years9 months
Submitted by sivasankari.t on Mon, 2013-02-11 07:45
There are some very good Excel macros out there that allow a relatively seamless interface between Excel and Primavera. However, I find the best results are obtained using and ODBC link from Access,
This type of link allows all information held in the BTRIEVE database to be dynamically updated through MS Access. E-mail me if you want more details.
if you go to tools and Update data dictionary,
you will find all the items that are built in the data base of P3, including cost and unit and any other Item,you have to use the standard names that built in the P3 for the cost and units.
to do that you have to export a standard file with the standard names first then fill in the form and then import the file with it is new data to p3.
other wise you can make custom data Item by with the fields cost,unit..etc.
2- the second problem, when you go to filter there is an option to add filter over filter,there's three option append , add and replace.
Best Luck
Ali
24 years 5 months
Member for24 years5 months
Submitted by Ulkutan Cimen on Fri, 2002-03-01 04:58
Cheers for all the quick replies.
Tomas, that Longest Path criteria in the filter specification answers me, thank you, I have just missed it, it seems.
Jeff and Colin, thanks for letting me know about those macros. I use P3 v 2.0b, it still has project.xls in it. I am working on it, my first few trials were unsuccessful. I may contact you if necessary.
Daryl, I am not a very good at Access yet so I will keep your reply for future reference.
And Reynaldo, I've got a bit too many resources in my current project, I was trying to avoid the time I would consume to build the resource dictionary. Thanks for your concern.
23 years 9 months
Member for23 years9 months
Submitted by Colin Cropley on Fri, 2002-03-01 04:31
On the P3 3.1 CD, there is a folder called \UTILS\Excel. In that folder, there are two files: PROJECT.XLS & ProjectMod.XLS. These are macro driven and access the underlying P3 database to enable the user to manipulate and add to the various P3 dictionaries in Excel and put them back into the P3 project.
If you do not have the 3.1 CD, send me an email and I can email the file to you.
Regarding the critical path filter question, if you sort by TF, you will get the most critical activities first, usually all part of the one critical path. If you have mixed calendars and thus the TF changes through the longest path, you will get fragments of the path with different TF values, corresponding to the different calendar activities.
You will then have to check the dependencies to see how the path links between the various mixed calendar activities.
Grouping by calendar may help work this out.
Colin Cropley
24 years
Member for24 years1 month
Submitted by Reynaldo Durana on Fri, 2002-03-01 02:03
I think you can not import resource dictionary in P3 from spreadsheet including the
Price/Unit & limits.but for me you can just input manually the price/unit & limits
for every resource name & it is not time consuming operation because in a project usually we don’t have so many resource name to be loaded in P3 or if you have
similar project before you can transfer the resource dictionary to the new project
& edit if there’s some inconsistency.
Your question #2 about filtering the longest path it was replied already.
24 years 6 months
Member for24 years6 months
Submitted by Tomas Rivera on Thu, 2002-02-28 10:26
Regarding your question number 2. In the Filter Specification window, you can choose a schedule parameter called "longest path".
I hope this was your question.
Tomas Rivera
24 years 4 months
Member for24 years4 months
Submitted by Jeff Williamson on Thu, 2002-02-28 08:09
On the P3 CD you will find a excel macro that can populate the resource dictionary. Look for "project.xls". I would suggest doing a few test runs before doing it for real.
12 years 10 monthsHi All,I would like to write
Hi All,
12 years 9 monthsI WANT TO KNOW HOW TO LEVEL
I WANT TO KNOW HOW TO LEVEL RESOURSE IN PRIMAVERA P6
23 years 9 monthsRe: Resource Dictionary & Crtitical Path
Hi Mr.Collen
I am facing troubles in excel sheets utility working with p3.( I doubt may be the files are old).
If you can send for me these files,It will be good help from you.
thanks
Ali
1-the solution of the first problem is:
Best Luck
Ali
24 years 5 monthsRe: Resource Dictionary & Crtitical Path
Colin Cropley
24 yearsRe: Resource Dictionary & Crtitical Path
24 years 6 monthsRe: Resource Dictionary & Crtitical Path
Hi Ulku:
Tomas Rivera
24 years 4 monthsRe: Resource Dictionary & Crtitical Path
