Perhaps a software such as ScheduleReader can find its use in this scenario. This software sollution offers a visuall way to interact with the schedule and all of its data that resides in an .xer file. It is originally designed to replace the old way to look at project schedules as PDF in different practices and industries.
17 years
Member for17 years
Submitted by Farzin Farsi on Sun, 2020-11-01 22:49
For your convenience you can download a PDF version of the presentation by clicking on the following linK. You can also move to the links within the presentation and PDF version by clicking them.
1. If you are assessing a schedule claim then there should be a schedule specifications that says that you need a schedule in cpm format in its native form if P6 then an xer file.
2. The owness is ALWAYS on the party to prove the delay this can not be done using a pdf because you can not see the logic.
3. You can always take a pdf and convert it to an excel file there is no logic so you will have to use start on constraints for each activity some logic can be implied by looking at the activity and the dates. Ie install conduit successor pull wire.
4. There should be an accompanying narrative that expalins the process used and what was done to the schedule to prove the delay.
5. As a very simplistic example in the original schedule you have activiy A with 10 day duration and its successor is activity B with a 10 day duration with a start to start relation with a 5 day lag. Let's assume that this both of these activities were on the critical path with ) days of float.
____A_____
____B_____
now the claim or delayed schedule changed this from a Start to Start relationship with a log to a Finish to Start relationship and now BOTH activites are - 5 days behind schedule or delayed by 5 days.
____A____
____B_____
without having the native schedule data to see this change in logic its almost impossible to assess what has been done to the schedule. Therefore I cannot grant a time extension or validate the claim.
WHAT ARE YOU HIDING ? why are you hestitant to give the reviewer the necessary information in the proper format to perform this function.
16 years 3 monthsglad that I could help
8 years 7 monthsPerhaps a software such as
17 yearsMany thanks Zoltan
Many thanks Zoltan
17 yearsMany thanks Rafael for your
Many thanks Rafael for your response
21 years 8 monthsFor your convenience you can
http://www.mediafire.com/file/rw99olplwm1on9y/Resource+Driven+Schedule.pdf/file
http://www.mediafire.com/file/94yjmuu91o78e0x/What+is+Driving+my+Schedule.pdf/file
16 years 3 months1. If you are assessing a
____A_____
____B_____
____A____
____B_____
