Thanks for replying. I did clarify in a second post but somewhere above, not sure how the forum posts work. I keep posting twice as well.
I think what you describe and say isnt allowed is what I described as the hammock activity. While I still don't see why it isn't allowed as it is a real situation - P6 did let me do it in one place not in others. I would like to understand why.
I don't like the option of placing them as work steps as we lose visability in the schedule.
OK, so i changed the activityies from milestons to activities. P6 allowed me (ONCE) to create a SS predecessor and a FF successor with the main activity. However it allowed me to do it in one place but not in others. I read in an Old P3 textbook that this was a hammock activity / relationship.
What are the rules for creating this relationship. I do not see any difference bewteen the two areas of the schedule. one allows the other doesn't. I thought it was that i used a milestone rather than a Task dependent activity type but that isnt the difference.
21 years 8 monthsAs a workaround consider
As a workaround consider using FF links with ALAP logic.
Good Luck
16 years 3 monthsyou said "P6 did let me do it
you said "P6 did let me do it in one place not in others. I would like to understand why."
look at where it let you do it
what was the activity type
was the predcessors a SS realtionship ?
was the successor a FF relationship
was the precdessor a start milestone ?
was the predcesssor a finish milestone
was the successor a start milestone
was the successor a finish milestone ?
was the predcessor and or sucessor a LOE activitiy type.
look at where it worked in detail and then look for any anomolies of where you want to use it again and see what the differences are.
7 years 10 monthsThanks for replying. I did
Thanks Agsin
7 years 10 monthsOK, so i changed the
18 years 11 monthsBrian,You seem to be
Brian,
You seem to be attempting circular logic. I.e. Work Activity >(SS)> Deliverable A >(FF)> Work Activity. P6 won't let you do that.
Suggestions, either:
1. Break Work Activity into a Start portion and a Finish portion, then tie your deliverables in.
2. Enter your deliverables as Steps on the work activity rather than milestones.
Good luck, tom
16 years 3 monthsmake a new activity D give it
make a new activity D give it 0 days but keep the activity tyep as TASK not start milestone then you can tie to this
