Planning, Scheduling & Programming Discussion Member for 22 years 9 months Member for 22 years 9 months Submitted by Alexandre Faul… on Thu, 2020-04-09 17:02 Permalink ZoltanOK, I got it, thank Zoltan OK, I got it, thank you Alexandre Member for 16 years 3 months Member for 16 years 4 months Submitted by Zoltan Palffy on Wed, 2020-04-08 13:38 Permalink Hello Zoltana) a non-labor Hello Zoltan a) a non-labor resource cannot have CY or LF or anythnig elese than hrs/day or days/week for a unit a non labor can have unist/time but not quantities but you can for material b) a material resource cannot use any unit that was not previously defined in the Admin categories but you can for materail c) if the resource being assigned to a task has a Default Units per time = 1, P6 will multiply 1 x the task duration. correct and you can then change this to whatever the uits should be Member for 22 years 9 months Member for 22 years 9 months Submitted by Alexandre Faul… on Wed, 2020-04-08 12:57 Permalink Hello ZoltanI cannot make Hello Zoltan I cannot make your suggestion to work: a) a non-labor resource cannot have CY or LF or anythnig elese than hrs/day or days/week for a unit b) a material resource cannot use any unit that was not previously defined in the Admin categories c) if the resource being assigned to a task has a Default Units per time = 1, P6 will multiply 1 x the task duration. Can you tell me where I am wrong? Thank you Alexandre Member for 16 years 3 months Member for 16 years 4 months Submitted by Zoltan Palffy on Tue, 2020-04-07 13:13 Permalink my answer is simialr I would my answer is simialr I would create a non-labor resource with a default unit/time = 1 hr (NOT zero) because anything multipliedd by zero is zero Then I will assign this resource to activities, and enter the "quantity" of the material (not 1) in the Budgeted Units field i.e. CY of concrete, tons of steel, LF of conduit in the Activity type make sure that the duration type is set to Fixed Duration and Units / Time Member for 22 years 9 months Member for 22 years 9 months Submitted by Alexandre Faul… on Tue, 2020-04-07 11:31 Permalink Hello Usman,I presume that Hello Usman, I presume that you are working with Primavera P6, and mentionning equipment (non-labor) resources? I would create a non-labor resource with a default unit/time = 0 hr (zero) Then I will assign this resource to activities, and enter "1" in the Budgeted Units field; if the Activity type (Activity Details, General) is set to Fixed Duration and Units / Time, nor the Duration and Units per time will change. Hope this will help you Alexandre Log in or register to post comments
22 years 9 monthsZoltanOK, I got it, thank
Zoltan
Alexandre
16 years 3 monthsHello Zoltana) a non-labor
Hello Zoltan
22 years 9 monthsHello ZoltanI cannot make
Hello Zoltan
Thank you
Alexandre
16 years 3 monthsmy answer is simialr I would
22 years 9 monthsHello Usman,I presume that
Hello Usman,
Alexandre
