Planning, Scheduling & Programming Discussion Member for 16 years 3 months Member for 16 years 4 months Submitted by Zoltan Palffy on Tue, 2020-02-18 14:32 Permalink for the most part this is for the most part this is true but some dates can be imported. But generally speaking it is beacuse they fields are calculated What is it you want to import Also you can use SDK and import anything Member for 14 years 5 months Member for 14 years 5 months Submitted by soohyla on Mon, 2020-02-17 14:20 Permalink Hi Santosh BhatMeaning only Hi Santosh Bhat Meaning only certain field in P6 can be loaded in excel and then imported back right? Thank you Santosh! Member for 20 years 6 months Member for 20 years 7 months Submitted by Santosh Bhat on Sun, 2020-02-09 11:23 Permalink The best method is to export The best method is to export out a sample of data, continnue populating the list and then import. Note that any field exported with a (*) cannot be imported - usually becuase this is a calculated field - such as dates. Log in or register to post comments
16 years 3 monthsfor the most part this is
14 years 5 monthsHi Santosh BhatMeaning only
Hi Santosh Bhat
Thank you Santosh!
20 years 6 monthsThe best method is to export
