Planning, Scheduling & Programming Discussion Member for 6 years 2 months Member for 6 years 2 months Submitted by Akhileshwar on Mon, 2019-12-16 10:43 Permalink Thanks Thanks Member for 21 years 8 months Member for 21 years 8 months Submitted by Rafael Davila on Fri, 2019-12-13 22:29 Permalink https://www.replicon.com/cust https://www.replicon.com/customer-zone2/kb-2810/ Member for 16 years 3 months Member for 16 years 4 months Submitted by Zoltan Palffy on Fri, 2019-12-13 13:53 Permalink if you have codes in that if you have codes in that layout it will only work with the project that the codes were created in. Member for 20 years 6 months Member for 20 years 7 months Submitted by Santosh Bhat on Fri, 2019-12-13 00:10 Permalink If your layout uses activity If your layout uses activity codes or UDF fields then it will not work because they are referencing field ID's from a different database that wont exist in the destination database. You will have to rebuild this part of the layout manually. Log in or register to post comments
6 years 2 monthsThanks
21 years 8 monthshttps://www.replicon.com/cust
16 years 3 monthsif you have codes in that
20 years 6 monthsIf your layout uses activity
