With glass facade do you mean Windows built into the ecternal wall or a free standing glass facde fixed to the structure.
With windows you can use timber sub frames to form the openings and plaster up to sub frame with a stop bead.
The windows than have to be fixed from the outside.
If it is a fre standing facade then it is the structure that determines the start date because the building has to be checked for line and level before the secondary support frame si fixed with the correct shims. Normally there is no interface with a plaster finish.
You can start internal blockwork and plastering works. But only the blockwork terminations work to the Glass facade works will be pending. You can update the activity too 99% or something like that, Until the Facade is closed then you can complete your blockwork termination.
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Tue, 2019-01-22 13:43
if all you are worried about is getting dirty then protect the glass with plastic or some other material.
Some considerations depends on your climate where you are performing the plastering work the ambient temperature must be higher than 40 degrees. Usually you want the building enclosed and weatehr tight before you begin finish work such as plastering.
14 years 3 monthsthank you all for your reply,
thank you all for your reply, appreciate it
Laith Batarseh
19 years 10 monthsHi LaithWith glass facade do
Hi Laith
9 years 2 monthsYou can start internal
16 years 3 monthsif all you are worried about
