you usually get this error when the format of the excel file being imported is different from the current user prefernce settings and the project settings are different for these fields
Duration Type IE. fixed Duration and Units /time
Quanity type IE. hours
Date format IE. dd-mmm-yy
Currency format IE. Dollars
12 years 9 months
Member for12 years10 months
Submitted by bryanfardyanto on Fri, 2019-03-01 01:54
Dear All, please need your help with my problem Primavera 16.2, is not working properly the problem information :The User Preferences used to create this Excel file are not the same as your current preferences. Importing this file could corrupt your data. Please refer to Help for more information about importing data from Excel. Are you sure that you want to continue?
I exported out added my line list and activity numbering then it only adds the 1 activity on the way back in.... its getting frustrating! I tried my import template from 15.2 and it hasnt worked either.
You did not create the export file or the template you used. Create a similiar tempalte yourself by running an export. Then copy paste the data from the import you are trying to run to your new file. Should work with no problem.
12 years 9 monthsDear All , problem for
Dear All , problem for import excel file to primavera 16.2, maybe anyone can help solution information , [[wysiwyg_imageupload:6568:]]
16 years 3 monthsyou usually get this error
12 years 9 monthsDear All, please need your
8 years 6 monthsFor reference if anyone else
For reference if anyone else has this problem the Patch for 16.2.6 fixed the issue
8 years 6 monthsi am getting this errorERROR:
ERROR: Failed to find a matching object for Activity
8 years 6 monthsI exported out added my line
18 years 4 monthsYou did not create the export
