If using P6 Standalone with a SQL Express Database:
• The default Server Name is <machine name>\primavera.
• The default login (using SQL Authentication) is:
Username: SA
Password: Prima123Vera
• The default destination folder for the backup file is C:\Program Files\MSSQL\Primavera\MSSQL.1\MSSQL\Backup
Right click on "Databases" and choose "Restore Database".
Specify the new database name in the "To database" box. Select "From device" and browse tothe location of the .BAK (backup) file. Check the "Restore" box to select the backup set to be restored.
If moving the database to a different computer verify the path to the data file is correct.
Click on the Options Page and verify the Restore path matches the path to the current data files folder.
VERY IMPORTANT
After restoring a Primavera database you must resync the following database schema users: privuser and pubuser. The Resynch command resyncronizes the database with the login ID's privuser and pubuser on the server.
To resynch the privuser and pubuser, run this query against the newly restored database:
16 years 3 monthshope it worked
hope it worked
14 years 2 monthsThanks Alot Dear.
Thanks Alot Dear.
16 years 3 monthsIf using P6 Standalone with a
14 years 2 monthsI were working in windows 7
I were working in windows 7 and i changed it to windows 8.1, so i setup primavera 6 and when i tried to restore the backup file it failed.
can you explain how to restore database on microsoft SQL 2005.
16 years 3 monthswhat do you mean you changed
what do you mean you changed your windows you udated the version of windows ?
also can you type the error message the screen shot is too small to read
thanks
