Maybe the owner wants you to reschedule only what is left, or the remaining works, that is the only reason why i think he wants to make your progress to 0%.
Endralie G. Halog
11 years 4 months
Member for11 years4 months
Submitted by endraliehalog on Wed, 2014-10-22 11:28
Endralie G. Halog
16 years 3 months
Member for16 years4 months
Submitted by Zoltan Palffy on Tue, 2014-10-21 13:23
chnaging ALL percent completes to zero will not only change the previous months planned percent cmplete it will change all of the previous progress to zero thus giving you a baseline (this is if you also remove the actual start and or finish dates).
16 years 3 months
If you change all the percentage complete to zero (for the completed activities) in the current schedule( replanned schedule), the completed activities will be rescheduled with its original duration.
For eg: Activity was planned to complete in 10 days and actualy finished in 5 days. When you remove the % complete, it will be rescheduled with 10 days duration. There may be several activities like this. This could change the dates of the remaining sections of the replanned schedule (I hope there will be links between completed section and the remaining section).
I believe that the client wants to change the data date to the commencement date.
By the way what was the reason to replan the schedule? If it is Client delay (happened before the present data date) then the delay scenarios will be deleted by removing the actuals. In my understanding, if extension of time is agreed the revised baseline to be created from the current schedule and for the remaining percentages.
Kannan
18 years 9 months
Member for18 years10 months
Submitted by Dieter Wambach on Thu, 2014-10-16 08:40
Did your project already start? Are there actual percent complete greater than zero?
The first official BL is the first plan accepted by all parties. Life is hard, so frequently there are major differences between plan and current status of the project due to e.g. claims, delays, client's additional wishes, force majeure etc.
This will lead to a re-planning and a NEW, additional BL. In my opinion, if there is a common sense, actual percent complete may change as well. Mostly activities are added. This will reduce the weight of your current activities.
I would check the intentions of your client.
In anycase: Keep your first BL for further reference; current BL will be the new one.
11 years 4 monthsHi, Maybe the owner
Endralie G. Halog
Endralie G. Halog
16 years 3 monthschnaging ALL percent
17 years 4 monthsHi Ali,If you change all the
Hi Ali,
Kannan
18 years 9 monthsHi Ali Did your project
Hi Ali
Hope I understood your point correctly.
Good planning
