Creating Project Calendars
16 years 3 months
this is confusing
1st line you said
Does anybody have a procedure on how to create a project calendar
Last line you said
It is NOT the procedure on how to create a calendar in Primavera.
12 years 10 months
1.CONTRACTOR will develop and submit its Project Calendar for review by COMPANY. CONTRACTOR’s Project Calendar will provide details and clarity on key dates, cut-off dates, meetings, submissions and any other required detail, documentation and events that will occur on a regular basis.
2.CONTRACTOR will maintain the Project Calendar so as to align with any agreed changes agreed with COMPANY and the updated Project Calendar will be re-submitted as changes occur. In any event, CONTRACTOR will review and re-issue the Project Calendar every (3) three months.
           3.CONTRACTOR will submit to COMPANY for review, its detailed Project Calendar procedure for implementing the provisions of the CONTRACT and specifically this clause. CONTRACTOR’s detailed Project Calendar procedure will describe CONTRACTOR’s methodology and systems for implementing the provisions of the CONTRACT, this Clause, and the requirements of COMPANY Standard Procedure,.
So does anyone have a template for the above description?Could anyone help me,and send the template to the my email:cpptangdeshengifl@163.com
Best regards.
Tang
19 years 10 months
Hi Skye
If you donn’t know how to do it say so and get the consequences.
Otherwise use the God given intelligence that you were born with and put something together using your own concepts.
If you don’t know what your boss requires he doesn’t either. Ask him for a template to check if he does.
Get your ideas down on a spreadsheet - review the results - check it against what you think is reasonable - and then submit it for review.
If in doubt bluff and bullshit will baffle brains.
Just remember Bullshit won’t baffle Bullshit.
Mike Testro.
19 years
Mike
thanks again
unfortunately the company wants me to write a procedure.
I really want the wording to be clear and consise.
If somebody had already written a good one, it would have been helpful as a go by
regards
19 years 10 months
Hi Skye
In that case just use your own knowledge of your companies procedures. Forget about any other.
Use an excell spreadsheet.
1. Set down the various reports required.
2. Set down the points in the project from which the reports have to be generated.
3. Set down a reasonable time for the reports to be put ogether
4. Add 3 and 2 and you have a report required date.
Alternatively
1. Take the required report date.
3. Deduct 2 from 1 and you have the time required to generate the report.
Either of these can then be standardised for any project.
Mike Testro.
19 years
Hi Mike
many thanks for the reply.
Possibly like milestones but more like a ’A Project Calendar’
I need to write a coompany procedure that can be implemented wherever in the world we have projects
A procedure that will layout the calendar format for all those who need it on the project. All report cut off dates will be need to shown from company financial reports to dates when internal project review take place.
I am sure somebody can lay their hands on the old Brown and Root procedure
regards
19 years 10 months
Hi Skye
I think you may be confusing calendars with milestones.
Items that require action on a certain date on a programme are best expressed as milestones - using logic links or "end by" flags to fix them in the chart.
Calendars are used to set up non working periods such as weekends - holidays - predicted weather etc.
